Yes it's a bit advanced. You need to edit the registry, the key you want
is:
HKEY_CURRENT_USER\Software\Autodesk\DWFWriter\2
In here you will see "Publish Directory". Place the full path to the
existing directory here.
"John Herridge, AIA" wrote in message
news:40a52c69$1_3@newsprd01...
> If no prompt for file is selected, then the default directory is:
> C:\Documents and Settings\(user name)\My Documents\Autodesk DWF Writer
> Is there a way to change this directory? I would like the file by default
> to go to the same directory as the source file.
> John Herridge, AIA
> AEC CADCON, Inc.
> www.aeccadcon.com
