Rodney is correct. In fact the DWF Composer installer will allow
installation until a previous DWF Viewer has been uninstalled from the
client's machine. However the next rev of the DWF Viewer product will allow
both products to reside side by side on the clients machine and each will
function perfectly as standalone applications. However when the ADV control
(shared by both products) is embedded in a web page, Composer will get
precidence when it is available on the user's machine. But there will be an
API available as well to force the HTML page to use DWF Viewer if it is
available.
Larry Horner
"Rodney McManamy - CADzation" wrote in message
news:40c0aa1d$1_2@newsprd01...
> I don't think you can have both the viewer and the Composer installed on
the
> same machine under normal conditions. The way one would think that it
would
> work is that it brings up the last one you used like doing
> AutoCAD.Application would bring up the last AutoCAD you used. Since
> basically Composer is the viewer with additional features I don't know why
> except for testing one would want to bring up just the viewer. Composer
> doesn't add that much overhead from what I can see.
> Rodney McManamy
> President
> CADzation
> rmcmanamy@cadzation.com
> 518 South Route 31 Suite 200
> McHenry, IL 60050
> www.cadzation.com
> Providing Industrial Strength
> PDF & DWF Solutions to the
> Global CAD Marketplace.
> "fonitsua" wrote in message
> news:25498847.1086354834752.JavaMail.jive@jiveforum1.autodesk.com...
> > Using VBScript, I want to bring up DWF Viewer vs. DWF composer based on
a
> decision criteria. I have an ASP page that that redirects to two other
ASP
> pages based on decision. However since Composer and Viewer has same
ClassID,
> both pages bring up the Composer. Thanks in advance for help.
