Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
DWF Viewer Javascript API
7 REPLIES 7
Message 1 of 8
5604 Views, 7 Replies
There are a few examples of javascript code on the net for controlling the DWF viewer when embedded in a webapage. Is there a comprehensive guide to all available functionality.
I am looking for a way to make the Selection be turned on by default (or a method of controlling with javascript) without having to either select the arrow from the toolbar or use the right click menu.
Also does anyone know of a way to change the object params using javascript, I have tried modifying them with the DOM but it appears that once the dwf object is loaded the params cannot be changed without a complete page refresh.
Any help greatly appreciated
Paul M
7 REPLIES 7
Message 2 of 8
Its OK I have found the solution by trial and error.
I would like to know however if there is a way in which the current selected object in the dwf viewer can be deselected using javascript, because selecting the currently  selected object does not  cause an event to fire
PM
Message 3 of 8
I have managed to find a solution to the above also.
What I would really like to know is if the properties palettes can be disabled so they do not pop up (if the user has them turned on)  when an object is clicked on.
I have tried various permutations of:
ADViewer.ECompositeViewer.Commands('OBJECTPROPERTIESBAND').Enabled = false;
but this does not seem to work
any help greatly apprecciated
PM
Message 4 of 8
vgottipa
Try setting AdViewer.AutoOpenPalettesDisabled = 1
Message 5 of 8
in reply to: vgottipa
Many thanks that works great on the latest plug-in
does anyone know why the design review plug-in that gets downloaded from the Autodesk Website is the 2009 version?
is there a CAB file in existence anywhere for the 2012 or 2013 browser plug-in (the full design review download that includes the plug-in is over 700MB in size)
regards
Paul M
Message 6 of 8
BrunoMeier7845
Can you Post the Solution, have the Same Quentin, how to change properties with the API. Thanks
Message 7 of 8
BrunoMeier7845
Can you Post the Ideal, how to deselect all selected Objekts in the viewer. I can Not find any Event for that. Tanks
Message 8 of 8
in reply to: BrunoMeier7845
There is this: http://through-the-interface.typepad.com/through_the_interface/2014/05/javascript-in-autocad-viewing...
but it's through Autocad, if you want something like freewheel used to be, use the 360 api? Which I do't think is out yet, but I'm assuming it works something like freewheel used to, tech preview: https://autodesk360.com/
using an iframe:
<iframe scrolling="no" frameborder="0" hspace="0" src="https://360.autodesk.com/Public/Embed?hash=be253600ed6e4b4089526e8436478836" width="430" height="619" allowtransparency="true" style="border: medium none;"></iframe>
 Personally I would use an <object> with an iframe fallback:
<!--[if !IE]>-->
   <object data="https://360.autodesk.com/Public/Embed?hash=be253600ed6e4b4089526e8436478836" type="text/html" style="width:100%;height:50em;" class="model">
      <p>Sorry. This content cannot be rendered (non-IE object).  Stop living in the past and upgrade to <a href="http://www.abetterbrowser.com">a better browser</a></p>
   </object>
<!--<![endif]-->
<!--[if IE]>
  <iframe src="https://360.autodesk.com/Public/Embed?hash=be253600ed6e4b4089526e8436478836" type="text/html" style="width:100%;height:50em;" class="model">
     <p>Sorry. This content cannot be rendered (IE iframe).  Stop living in the past and upgrade to <a href="http://www.abetterbrowser.com">a better browser</a></p>
  </iframe>
<![endif]-->
the endgame woulde be if you could include
<script src="http://code.jquery.com/jquery-1.7.1.js"></script>
    <script src="js/three.min.js"></script>
    <script src="js/controls/TrackballControls.js"></script>
    <script
      src="http://app.autocad360.com/jsapi/v2/Autodesk.AutoCAD.js">
    </script>
    <script src="js/acadext.js"></script>
    <script src="js/threesolids.js"></script>
 on your own webpage and embed a div to view a model like
<div class="modelviewer"><object data="mysite/myfolder.model.dwf" type="text/html" style="width:100%;height:50em;" class="model">
   </object></div>
