Design Review
tagbagz
Message 1 of 8 (1,936 Views)
DWF Viewer Javascript API
1936 Views, 7 Replies
08-15-2012 01:18 AM
There are a few examples of javascript code on the net for controlling the DWF viewer when embedded in a webapage. Is there a comprehensive guide to all available functionality.
I am looking for a way to make the Selection be turned on by default (or a method of controlling with javascript) without having to either select the arrow from the toolbar or use the right click menu.
Also does anyone know of a way to change the object params using javascript, I have tried modifying them with the DOM but it appears that once the dwf object is loaded the params cannot be changed without a complete page refresh.
Any help greatly appreciated
Paul M
tagbagz
Message 2 of 8 (1,923 Views)
Re: DWF Viewer Javascript API
08-17-2012 03:24 AM in reply to: tagbagz
Its OK I have found the solution by trial and error.
I would like to know however if there is a way in which the current selected object in the dwf viewer can be deselected using javascript, because selecting the currently  selected object does not  cause an event to fire
PM
tagbagz
Message 3 of 8 (1,916 Views)
08-17-2012 08:13 AM in reply to: tagbagz
I have managed to find a solution to the above also.
What I would really like to know is if the properties palettes can be disabled so they do not pop up (if the user has them turned on)  when an object is clicked on.
I have tried various permutations of:
ADViewer.ECompositeViewer.Commands('OBJECTPROPERTIESBAND').Enabled = false;
but this does not seem to work
any help greatly apprecciated
PM
Active Contributor
vgottipa
Message 4 of 8 (1,885 Views)
08-20-2012 07:40 AM in reply to: tagbagz
Try setting AdViewer.AutoOpenPalettesDisabled = 1
tagbagz
Message 5 of 8 (1,880 Views)
08-20-2012 09:41 AM in reply to: vgottipa
Many thanks that works great on the latest plug-in
does anyone know why the design review plug-in that gets downloaded from the Autodesk Website is the 2009 version?
is there a CAB file in existence anywhere for the 2012 or 2013 browser plug-in (the full design review download that includes the plug-in is over 700MB in size)
regards
Paul M
Member
BrunoMeier7845
Message 6 of 8 (1,606 Views)
10-15-2012 10:02 PM in reply to: tagbagz
Can you Post the Solution, have the Same Quentin, how to change properties with the API. Thanks
Member
BrunoMeier7845
Message 7 of 8 (1,605 Views)
10-15-2012 10:04 PM in reply to: tagbagz
Can you Post the Ideal, how to deselect all selected Objekts in the viewer. I can Not find any Event for that. Tanks
New Member
mmemma
Message 8 of 8 (279 Views)
06-05-2014 12:36 PM in reply to: BrunoMeier7845
There is this: http://through-the-interface.typepad.com/through_the_interface/2014/05/javascript-in-autocad-viewing...
but it's through Autocad, if you want something like freewheel used to be, use the 360 api? Which I do't think is out yet, but I'm assuming it works something like freewheel used to, tech preview: https://autodesk360.com/
using an iframe:
<iframe scrolling="no" frameborder="0" hspace="0" src="https://360.autodesk.com/Public/Embed?hash=be253600ed6e4b4089526e8436478836" width="430" height="619" allowtransparency="true" style="border: medium none;"></iframe>
 Personally I would use an <object> with an iframe fallback:
<!--[if !IE]>-->
   <object data="https://360.autodesk.com/Public/Embed?hash=be253600ed6e4b4089526e8436478836" type="text/html" style="width:100%;height:50em;" class="model">
      <p>Sorry. This content cannot be rendered (non-IE object).  Stop living in the past and upgrade to <a href="http://www.abetterbrowser.com">a better browser</a></p>
   </object>
<!--<![endif]-->
<!--[if IE]>
  <iframe src="https://360.autodesk.com/Public/Embed?hash=be253600ed6e4b4089526e8436478836" type="text/html" style="width:100%;height:50em;" class="model">
     <p>Sorry. This content cannot be rendered (IE iframe).  Stop living in the past and upgrade to <a href="http://www.abetterbrowser.com">a better browser</a></p>
  </iframe>
<![endif]-->
the endgame woulde be if you could include
<script src="http://code.jquery.com/jquery-1.7.1.js"></script>
    <script src="js/three.min.js"></script>
    <script src="js/controls/TrackballControls.js"></script>
    <script
      src="http://app.autocad360.com/jsapi/v2/Autodesk.AutoCAD.js">
    </script>
    <script src="js/acadext.js"></script>
    <script src="js/threesolids.js"></script>
 on your own webpage and embed a div to view a model like
<div class="modelviewer"><object data="mysite/myfolder.model.dwf" type="text/html" style="width:100%;height:50em;" class="model">
   </object></div>
