Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
DWF Viewer aX control fails to build
2 REPLIES 2
bsitler
1529 Views, 2 Replies
I am trying to add the DWF Viewer to a WinForms project in Visual Studio 2010.  As my machine is x64bit, I've changed the project properties under compile/advanced comp.../Target CPU to x86bit.  I can add the control just fine, but as soon as I try to build Visual Studio crashes.  I've tried targeting .Net Framework 3.5, but had the same issue.  Design Review works fine on my computer, so I'm thinking that this should work.
Any thoughts on what else I should try?
Cheers
2 REPLIES 2
herbert.he
in reply to: bsitler
Thank you for reporting this issue.
Please to try the solution provided by BachmannGmbH in the post:
http://forums.autodesk.com/t5/Autodesk-Design-Revi​ew/ADR-2011-Api-amp-VB2010-Express/m-p/2900418/hi...
Hope that helps.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
bsitler
in reply to: herbert.he
Thank you.  Creating a user control in VS 2008 Express Target Framework 2.0 with the DWF viewer and then using the dll in VS 2010 works well.
Cheers
