Design Review
Distinguished Contributor
kstate92
Message 1 of 3 (454 Views)
DWF settings when opening a DWG
454 Views, 2 Replies
08-19-2011 06:41 AM
ADR 2012 with companion TrueView 2012.  When opening a DWG file from within ADR, what are the DWF settings TrueView uses?  I am assuming it is a DWF6 ePlot.pc3, but amazingly, I have 18 copies of this file scattered about on my C: drive (most from ADR for different dpi settings (?)).  Opening most of our D-size drawings from within ADR result in DWF files with part of the drawing clipped off, so I need to adjust the plotted margins, but I don't know where to look, or even if these settings are adjustable when using ADR to open DWGs.  DWF, not DWFx.
KState92
Inventor Professional 2014 64 SP2
Windows 7 Pro 64 bit - SP1
Xeon E5-1620
16 GB Ram
Quadro 4000
If you want total control, open the DWG files in TRUEVIEW and set the DWF parameters and create them from there: I believe DVR simply uses whatever settings are existing in the pagesetup and simply redirects to the DWF driver.
pendean
Message 2 of 3 (440 Views)
Re: DWF settings when opening a DWG
08-22-2011 06:00 AM in reply to: kstate92
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
kstate92
Message 3 of 3 (436 Views)
08-22-2011 06:30 AM in reply to: pendean
I'll give that a try, Thanks.
I see they still haven't fixed the filter papers bug regarding the un-deselectable ISO Full Bleed B1 paper size; no rush, Autodesk.
KState92
Xeon E5-1620
16 GB Ram
Quadro 4000
