When I use the Copy Current View command in Design Review to copy a .dwf into Microsoft Word for technical documentation, I often have problems with printing electronic copies.
If I use Adobe Acrobat Pro to create a .pdf, or if I use the Microsoft XPS Document Writer to create an .xps, the .dwf prints with black shapes covering all the angles. (An L looks like a triangle, for example, because the the interior angle fills with black. See attached .jpegs for more info.) If I use PDF995 to create the .pdf, I don't have this problem, but I lose a lot of my custom properties.
My IT department has looked into the issue a little bit, and all they can tell me is that there is some sort of problem with how it is pulling the information from the .dwf. Any suggestions?
