Design Review
Member
florencioparaon8696
Message 1 of 9 (1,286 Views)
DWF highlighter tool in PDF file
1286 Views, 8 Replies
08-28-2012 01:35 PM
How do I get the highlighter input to show as transparent in a PDF print of the DWF file? See attachments.
MikeKos
Message 2 of 9 (1,172 Views)
Re: DWF highlighter tool in PDF file
10-01-2012 01:16 PM in reply to: florencioparaon8696
I wouldn't bother. Seriously. If you're exporting to PDF anyway, just highlight your text in Acrobat:
http://www.ehow.com/how_7249964_highlight-text-pdf-files.html
Just consider the user population. How many people use Autodesk, and how many use Acrobat?
(Not to mention, there are dozens of imitators and clones of Acrobat, some of which are freeware
or shareware, but functionally equivalent. Check out the available downloads at http://www.planetpdf.com
and http://forums.planetpdf.com/ .)
It's the equivalent of asking a complex technical question about the Icelandic language, when you
could be asking how to do the same thing in English. Or Mandarin. Or French or Portugese.
But not Icelandic, or Old Norse. (With which Icelandic shares more similarities than any of the other
modern Scandanavian languages.)
pendean
Message 3 of 9 (1,160 Views)
10-02-2012 04:45 AM in reply to: florencioparaon8696
As noted above, mark up PDFs directly: but you don't have to buy Acrobat, you can use freeware like FOXIT READER to do the same.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
New Member
mangeshsgadre
Message 4 of 9 (1,046 Views)
10-16-2012 02:47 AM in reply to: florencioparaon8696
Is there any solution on this issue? We are also facing this problem.
Is there any setting in ADR itself so that the highlight will remain transperent when we convert it to pdf.
pendean
Message 5 of 9 (1,038 Views)
10-16-2012 05:07 AM in reply to: mangeshsgadre
Nope.
Member
florencioparaon8696
Message 6 of 9 (1,030 Views)
10-16-2012 07:02 AM in reply to: pendean
Thanks. I use Bluebeam Revu now. Works. A lot better than Autodesk and Adobe.
Member
florencioparaon8696
Message 7 of 9 (1,029 Views)
10-16-2012 07:03 AM in reply to: mangeshsgadre
Use Bluebeam Revu.
pendean
Message 8 of 9 (1,013 Views)
10-17-2012 06:08 AM in reply to: florencioparaon8696
That's pretty much what all the responses here have talked about, use a PDF markup tool for PDF output files.
Member
valluvana
Message 9 of 9 (695 Views)
11-26-2012 10:06 AM in reply to: florencioparaon8696
I have similar problem.  I was using DWF extensively as paperless option until I started with Bluebeam.  Bluebeam has great features that outweighs DWF and Adobe Pro.  I am not sure why Autodesk cannot make DWF markups printable.
