Design Review
61 Kudos
Post 1 of 4
DWF file size
404 Views, 3 Replies
11-13-2013 09:12 AM
When I convert a scanned PDF to DWF the file size balloons as much as 5 times.  Whether I print to DWF using the DWF writer for 2D printer driver or open the PDF in Design Review 2013 and save as DWF or DWFx makes no difference.
Is there a better way or are we stuck with multimegabyte files when I could stick with PDF and keep it under 1Mb per file?
David Miller
*Expert Elite*
1,589 Kudos
Post 2 of 4
Re: DWF file size
11-13-2013 04:38 PM in reply to: dmiller
There is no relationshhip between those file types: it's content and your output (and perhaps even the lackluster driver being used to create the other format) that controls files sizes.
Scanned PDFs are a huge collection of points (your drawing plus "noise". DWF triesd to create Vector files, so each point is actually a point, taking up code space in the file definition. A billion points bulk up file size more than one continous line of the same length.
PDF= standard paint brush.
DWF= super fine pointed pen.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
61 Kudos
Post 3 of 4
Re: DWF file size
11-13-2013 06:44 PM in reply to: pendean
My understanding of the DWF format is that it is based on the ISO 29500 Open Document format which is basically a ZIP file collection of objects which can include graphics such as PNG, BMP, etc.  Seems to me a PDF to DWF conversion would be mostly just a repackaging, not something requiring a 5:1 size expansion,  Are you saying it is really trying to convert raster data to vector?  Are the PDF graphics being converted to a graphics memory hog format like BMP instead of something more efficient like PNG?  If so then I'll just stick with PDF.  I had hoped I could use DWF to leverage the built in markup capabilities of Vault and Design Review without having to switch to Acrobat during change order reviews.
*Expert Elite*
1,589 Kudos
Post 4 of 4
Re: DWF file size
11-14-2013 04:52 AM in reply to: dmiller
You might want to ask in the VAULT forum how other VAULT users handle your issues: I bet you're not the first (or last) :smileyhappy:
Post to the Community
New Post
