DWF does not inherit custom view settings (Ground Plane/Shadow) from Inventor 3D-model
Steps to reproduce:
1. Run Inventor. Enable "Ground Plane" and "Ground Shadows" options;
2. Open fresh copy of C:\Users\Public\Documents\Autodesk\Inventor 2014\Samples\models\Parts\OilPan\OilPan.ipt;
3. Export IPT to OilPan.DWFx and open result in ADR;
4. Enable "Drop Shadows" option;
***Make sure shadow in DWFx is placed alike ground plane in IPT
5. Open fresh copy of OilPan.ipt in Inventor, click LEFT face on View Cube and execute "Set current view as TOP" command;
6. Export IPT to to OilPan_2.DWFx and open result in ADR.
Make sure shadow in OilPan_2.DWFx is the same as in OilPan.DWFx
Issue is actual for:
Inv2014 SP2 upd2
Inv2015 SP1
