Hi Peter,
I'd like to look into the problem that you are having. Can you please tell me what application(s) you are currently using to create your DWF files? Also, if you can provide me with any additional information regarding the process you are currently using to create the DWF files, that would be helpful also. (For example, do you PUBLISH your DWFs from an AutoCAD application, PLOT to DWF using the DWF6 ePlot.pc3, or do you use DWF Writer to create your DWF files?)
Scott Lillibridge
Software Quality Assurance Analyst - Viewers
