Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
DR can't open this file when exported from ACA
3 REPLIES 3
ntellery
483 Views, 3 Replies
Had lots of problems trying to export to DR which can't then open the file.  Narrowed it down to this MVB model of a sink/tap.  If ACA can model it, shouldn't DR be able to display it?
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
3 REPLIES 3
pendean
in reply to: ntellery
ADR is a DWF viewer, and it uses the free dwg viewer (requires the ACA OE to be installed I believe) to convert a file, if it all works: why not export to DWFx from ACA first, if you already have ACA? Skip a step by only using the software you know and control fully.
ntellery
in reply to: pendean
That’s what I have done but DR can’t open it. Here’s the file ACA exports that AD can’t open. Nathan
pendean
nothing attached.
