OK, thanks Susan.
I'll check back later!
Bob
"Susan Scott [Autodesk]" wrote in message
news:409a7220$1_3@newsprd01...
> Bob -
> No, there are no APIs for markup in this release. All the APIs in DWF
> Composer are the same ones that are also in the DWF Viewer. We are
looking
> to add some additional APIs to DWF Composer in the next release.
> Susan Scott
> Autodesk Viewers QA
> "Bob" wrote in message news:409a64b6$1_1@newsprd01...
> > Susan,
> > The advantage that Composer has is markup. The DWF Viewer help does not
> > mention markup API because there is no markup in DWF Viewer.
> > Is there API help for markup commands with Composer?
> > Bob
> > news:409a60e3$1_2@newsprd01...
> > > Bob - the API's are the same for the 2 products, except for the
> > differences
> > > called out in the DWF Composer HELP. My recommendation to you is:
> > > 1. read the DWF Composer introduction to the APIs
> > > 2. download the DWF Viewer API document and use it for your DWF
Composer
> > > work.
> > > Susan Scott
> > > Autodesk Viewers QA
> news:409a5a81$1_2@newsprd01...
> > > > Susan,
> > > > The link you provided to API help is for DWF Viewer. It hasn't been
> > > updated
> > > > for Composer.
> > > > Is there any API help for using the mark-up tools in Composer?
> > > > Thanks,
> > > > Bob
> > > > news:4098e071$1_3@newsprd01...
> > > > > Bob -
> > > > > DWF Composer's online HELP has a section titled "Programmer's
Guide:
> > > > > Introduction to the DWF Composer API". This section describes
some
> of
> > > the
> > > > > differences between the "DWF Viewer" API and the "DWF Composer"
API.
> > It
> > > > > also provides a link to download the API document:
> > > > > http://www.autodesk.com/developdwfcomposer
> > > > > DWF Composer's online help is available within the DWF Composer
> > > > application
> > > > > itself, or from the web: http://www.autodesk.com/dwfcomposer
> > > > > Susan Scott
> > > > > Autodesk Viewers QA
> > > news:4098d93e$1_2@newsprd01...
> > > > > > Hi John,
> > > > > > Is there an API help file that comes with Composer? Is there a
> > > document
> > > > > > available on the AutoDesk web site for reviewing changes to the
> API?
> > > > > > Bob
> > > > > > "John Schmier (Autodesk)"
> > wrote
> > > > in
> > > > > > message news:40982831$1_3@newsprd01...
> > > > > > > Composer will work with your existing web site written for the
> DWF
> > > > > Viewer.
> > > > > > > There are some API migration paths if you are using a compiled
> > > > language
> > > > > > such
> > > > > > > as VB or C# when re-compiling with Composer.
> > > > > > > "charlineavey" wrote in message
> news:132127.1083691241260.JavaMail.jive@jiveforum2.autodesk.com...
> > > > > > > > I purchased the DWF Composer. I have the current release of
> the
> > > > free
> > > > > > DWF
> > > > > > > Viewer on my machine when I installed Composer it asked me to
> > > > uninstall
> > > > > > the
> > > > > > > dwf viewer. This is a problem if the object code is different
> > > between
> > > > > the
> > > > > > > free one and the pay one because we have written a web rapper
> that
> > > > > > requires
> > > > > > > the object code to be the same as the free one.
