Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
Design Review Properties Band API
4 REPLIES 4
p.listo
454 Views, 4 Replies
Is there any way of disabling the Object Properties band and Model band that appear when an object is clicked?
I'm attempted to achieve this programmatically in a HTML / Javascript scenario, either via a HTML <param> or through the API via Javascript.
Paul
4 REPLIES 4
herbert.he
in reply to: p.listo
Thank you for your question.
You can use the code below to suppress all Palettes.
    ADViewer.AutoOpenPalettesDisabled = 1;
You can also to suppress a specified individual palette following the enum below:
    Suppress_None = 0, // default
    Suppress_All = 1,
    Suppress_Markups = 2,
    Suppress_Markup_Properties = 4,
    Suppress_Object_Properties = 8,
    Suppress_Sheet_Properties = 16,
    Suppress_CrossSections = 32,
    Suppress_TextPane = 64,
    Suppress_Views = 128,
    Suppress_Model = 256,
    Suppress_GridData = 512,
    Suppress_GridData_Object = 1024,
    Suppress_Default = 0
Please let me know if I can be of any further assistance.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
p.listo
in reply to: herbert.he
Thanks for your reply, it solved my problem for IE 8 and below.
This method does not seem to work across Internet Explorer 9.
Is there any workaround for this?
Kind Regards,
Paul
herbert.he
Thank you for your feedback.
It works well with IE 9 on my machine. I'd suggest you to retest it on another machine with IE 9. If it still doesn't work please attach your sample code for us to investigate.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
p.listo
My apologies, turns out it was a problem with our web server.
Thanks for your assistance,
Paul Listo
