Is there any way of disabling the Object Properties band and Model band that appear when an object is clicked?
I'm attempted to achieve this programmatically in a HTML / Javascript scenario, either via a HTML <param> or through the API via Javascript.
Paul
Thank you for your question.
You can use the code below to suppress all Palettes.
ADViewer.AutoOpenPalettesDisabled = 1;
You can also to suppress a specified individual palette following the enum below:
Suppress_None = 0, // default
Suppress_All = 1,
Suppress_Markups = 2,
Suppress_Markup_Properties = 4,
Suppress_Object_Properties = 8,
Suppress_Sheet_Properties = 16,
Suppress_CrossSections = 32,
Suppress_TextPane = 64,
Suppress_Views = 128,
Suppress_Model = 256,
Suppress_GridData = 512,
Suppress_GridData_Object = 1024,
Suppress_Default = 0
Please let me know if I can be of any further assistance.
Thanks for your reply, it solved my problem for IE 8 and below.
This method does not seem to work across Internet Explorer 9.
Is there any workaround for this?
Kind Regards,
Paul
Thank you for your feedback.
It works well with IE 9 on my machine. I'd suggest you to retest it on another machine with IE 9. If it still doesn't work please attach your sample code for us to investigate.
My apologies, turns out it was a problem with our web server.
Thanks for your assistance,
Paul Listo
