What size of paper is stored in your printer? If the size of the paper stored in your printer is A4 but you select ‘17x11' as the output size, then this issue you mentioned can happen.
ur company we distribute DWF drawings all over the world. We have simple 2D DWF paper sheets that since ADR 2010 do NOT fitting the paper.
I have tested all settings but nothing change the location of my scrinked drawing. Today we typically have a 1 inch border but on right side it can even be 1.5 inch. Our users are very puzzeled when they create publications and customer quotations into PDF with a drawing that is not presented correctly on a single piece of paper.
Our drawing system is very OLD and our DWF files are classic DWF 4/5 (NOT version 6).
What I noticed is that if I open this on a US Letter side setup ADR it will fit better then if I open it on european A4 paper size but still our margins remains to big...
Do you have any solutions to this?
Could it be that we can set up a default paper size / installation?
I send over a picture of 2 examples where we have problems.
Our users do NOT modify anything in ADR, VoloView, DWF Viewer, WHIP or any of the viewers they use. They only print it or create PDF.
Is it possible for me in format V00.42 or v00.50 to set an A4 size or Letter size paper border?
