I recently published a dwf file in which most of the viewports are scaled to 1" = 30'. I was attempting to demonstrate the 'measure' utility to a colleague and noticed that DR was calculating the distances incorrectly - it measures the length of my 30' scale bar (in multiple sheets) at 42.4', and my 80' scale bar in the locus plan at 113'. I have created dwfs before where this was not a problem, and am assuming that this is an issue with my drawing. However, I double-checked the viewport and the scale is 1:30. I also checked the scale in Civil3D's drawing settings (that's the program I'm using) and it's also set to 1" = 30'. What gives?
FYI - I am using a sheetset to generate a dwf for my entire planset. Could this issue have something to do with the fact that I have one sheet at 80 scale and others at 30 scale?
Thanks for the help,
Evan
