Design Review
Design Review
New Member
0 Kudos
Post 1 of 19
Design Review and Windows 7 64-bit
6126 Views, 18 Replies
10-13-2009 12:53 PM
Has anyone installed Design Review on a Windows 7 64-bit machine? I am getting an error Visual Studio 5 SP1 C++ Runtime (0x2: Failed downloading component.) Edited by: kelly3927 on Oct 13, 2009 7:59 PM
New Member
0 Kudos
Post 2 of 19
Re: Design Review and Windows 7 64-bit
10-19-2009 12:51 PM in reply to: kelly3927
Scratch install on new HP 6930p with ATI Mobility Radeon HD3400 running x64 Windows 7, all current patches thru last Tuesday's.
ADR 2010 dies at the splash screen when launched from the desktop, no errors, no program entry in the task list, killable process in process list only.
When launching from Library by double-clicking on a DWF, don't even get a splash screen, no errors, no program entry, etc.
Uninstalled and replaced with ADR 2009. Works like a champ.
HTH
New Member
0 Kudos
Post 3 of 19
Oh, and that ADR 2010 was fully hotfix'ed. Made zero diff.
Employee
0 Kudos
Post 4 of 19
10-26-2009 08:19 PM in reply to: kelly3927
Thank you for your report.
Please install the Visual C++ 2005 SP1 Redistributable Package (x86) from Microsoft's website manually: http://www.microsoft.com/downloads/details.aspx?familyid=200B2FD9-AE1A-4A14-984D-389C36F85647&displa...
Then try to install the Design Review again.
Please let me know if you have any further questions.
- Kenny Guo
Kenny Guo
SW Engineer
Autodesk, Inc.
Distinguished Contributor
3 Kudos
Post 5 of 19
11-03-2009 07:15 AM in reply to: kelly3927
I installed the C++ distributable pack (as directed) and then installed a clean version of DR 2010 and still no dice. Running Windows 7 x64 on a Dell M6400 laptop. Any other suggestions?
-Brian Hall-
-Brian Hall-
Product Support
18 Kudos
Post 6 of 19
11-04-2009 09:13 AM in reply to: kelly3927
Are you using Equitrac?
Shawn Niles
Autodesk Product Support
Shawn Niles
3 Kudos
Post 7 of 19
11-04-2009 10:03 AM in reply to: kelly3927
No, not using Equitrac.
-Brian Hall-
New Member
0 Kudos
Post 8 of 19
11-19-2009 07:19 PM in reply to: kelly3927
Similar error, ADR2010, Win7 Pro-64 Bit = "The application was unable to start correctly (0xc0000142). Click to close...."
Have applied all suggested MS & Autodesk fixes.
Disappointing and will delay corporate deployment.
Good advice?
New Member
0 Kudos
Post 9 of 19
12-14-2009 03:48 PM in reply to: kelly3927
We also have the same problem with Design Review and Windows 7 x64 :smileysad: "...uable to start..."
Employee
2 Kudos
Post 10 of 19
12-14-2009 03:54 PM in reply to: kelly3927
If you get the VC++ 2005 and VC++ 2008 redistributable packages, you use the "SP1" version. The older VC++ packages will work with the ADR installer.
Thank you,
Kevin
Kevin Moore
Test Development
AutoCAD
Autodesk, Inc.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
