We are using Design Review 2007 and have just tried to use the batch printing facility.
We go through the batch printing wizard, select the drawings, then setup the print, but when we click the 'print' button, nothing happens - the dialog dissappears, but the print job is not sent to the printer/plotter - we have tried on various printers, and none of them gets the job. We do not get the progress bar, as described in the help section.
However, we have found a work around - if we save the batch print job as a file (.bpj), we the right click, select open, and choose 'Autodesk Design review' from the program list - the job is then sent to the printer/plotter as required.
So it appears that we have a problem with the link between clicking the 'print' button, and the job being created/sent to printer from within Design Review. We have tried unistalling and reinstalling, but it is always the same.
We can send single plots/prints via the standard print button withiut any problems.
Has anyone else experineced this, or have any ideas how to correct the problem? We woudllike to roll this out to the whole office. but are holding back if batch plotting isn't as straight forward as it should be.
For info the compnent build versions are as follows:
Design Review Build version: 3.0.0.928
DWF Toolkit: 7.2.0.297
Whip! toolkit: 7.7.601.297
Heidi: 8.2.38.20
Thanks for any help/advice offered.
MJ
