Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
Creating multiple pages
4 REPLIES 4
robertlewis85
1456 Views, 4 Replies
I receive DWG files with multiple pages, for example ill be looking at a drawing and in the top right hand corner this will be page 1 of 7, I click right to view the next page and I view a different drawing.
What I want to know is how do you add additional pages to the project that your working on? For example IM working on a drawing/project at the min that I want to add photos to on a different page, but can't seem to work out how to do it, any ideas?
4 REPLIES 4
dickyshu
in reply to: robertlewis85
Thank you for posting.
As far as I know, Autodesk Design Review did not support add multiple pages directly, however, you can achieve it via below workaround:
  • Method 1:
Drag and drop the content file, which you want to add to current file/project, to the left List View panel. It will be merged into current file/project as a new page.
  • Method 2:
While open Design Review, press 'P' from your keyboard to take a screen snapshot. It will add a new page to your file/project, and then you need to modify that page according to your requirement.
Hope these would be helpful.
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Autodesk, Inc.
NLTim
I haven't used the dwf writer, though I assume that printing multipage documents is as easy as using a print dialogue.
When publishing/exporting from Revit, You can select the 2D/3D view that you want to include in the document.
As dickyshu sugests you can also drag dwf/pdf/image files onto the dwf window to add them to the document.
robertlewis85
in reply to: dickyshu
spot on, cant believe I missed that, so easy, thanks for your help.
ELinik
I read your suggestion regarding how to have many drawings in one DWF file.
If I press P, it does create a new drawing, but, as soon as I checked and other file this new page is vanished, and the original page is being replaced by the new file that they dragged, so I still end up having only one drawing in the file
