Design Review
Design Review
Active Member
0 Kudos
Post 1 of 6
Converting 3D DWG to DWF file
896 Views, 5 Replies
05-13-2008 01:35 AM
Hi
I am trying to convert a 3D dwg autocad file to 3D dwf file.but i cannot do this or by importing. i am trying to measure on 3d using DEsign Review. When choosing the paper size it does not give you the 3d option when trying to convert it
*V Joseph \(Beta & Customer Success Mana
Post 2 of 6
Re: Converting 3D DWG to DWF file
05-13-2008 05:46 AM in reply to: rockm
What version of AutoCAD are you using?
wrote in message news:5929291@discussion.autodesk.com...
Hi
convert it
Distinguished Contributor
0 Kudos
Post 3 of 6
05-13-2008 03:27 PM in reply to: rockm
Assuming you're using AutoCAD 2006 or newer, you can use the 3DDWFPUBLISH command from autocad to create the 3D DWF.
John
Active Member
0 Kudos
Post 4 of 6
05-21-2008 07:34 AM in reply to: rockm
I am using Autodesk design review
Active Member
0 Kudos
Post 5 of 6
05-21-2008 07:35 AM in reply to: rockm
Sorry i am using Autodesk Trueview
0 Kudos
Post 6 of 6
05-21-2008 09:08 AM in reply to: rockm
With Trueview 2009, select 3D DWF as your Page Setup.
The Help menu shows the step-by-step procedure for publishing 3D DWFs.
John
