Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
Converting 3D DWG to DWF file
5 REPLIES 5
1479 Views, 5 Replies
Hi
I am trying to convert a 3D dwg autocad file to 3D dwf file.but i cannot do this or by importing. i am trying to measure on 3d using DEsign Review. When choosing the paper size it does not give you the 3d option when trying to convert it
5 REPLIES 5
What version of AutoCAD are you using?
wrote in message news:5929291@discussion.autodesk.com...
Hi
convert it
Assuming you're using AutoCAD 2006 or newer, you can use the 3DDWFPUBLISH command from autocad to create the 3D DWF.
John
I am using Autodesk design review
Sorry i am using Autodesk Trueview
With Trueview 2009, select 3D DWF as your Page Setup.
The Help menu shows the step-by-step procedure for publishing 3D DWFs.
John
