Hello there,
I am looking for some information regarding the compatability between installing and running AutoCAD 2010 and Design Review 2013 on the same workstation, running Windows XP SP3.
I understand from the forums that Design Review and Trueview must be at the same level, but is this true for AutoCAD and Design Review as well?
If there is an Autodesk representative that can point me to some documentation regarding the product compatability matrix, or simply provide me with the information as to if it is or isn't, it would be greatly appreciated. I've been scouring the Autodesk support site for it without any luck.
Thank you very much!
JR
Are you just wanting to avoid installing TrueView 2013? While you wait for a staffer, I suggest you go ahead and install DTV since AutoCAD 2013 is current and 2014 is out this month or early next month and you will start getting files you can't open eventually anyway.
