Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
Bug in Composer showing text?
7 REPLIES 7
Message 1 of 8
316 Views, 7 Replies
I have found a strange behaviour with the dwfs attached.
The words "Linea Tre" in grey are NOT shown correctly in Composer, but are showed IN PROPER WAY in DWF viewer; so I assume that dwfs are ok and it's a Composer's problem
I use Italian version of both Composer and DWF Viewer.
Versions:
DWF viewer: 5.0.0.521
Composer: 1.0.0.2161
Solutions? It is a bug?
ing. Luca SIlvestri - Italy
7 REPLIES 7
Message 2 of 8
Still no reply? Is someone investigating on it?
Ty.
ing. Luca Silvestri - Italy
Message 3 of 8
Could you give us some more info? When you say the words are not displayed properly, what do you mean? Wrong size, wrong color, wrong font?
--Tim Clark
Message 4 of 8
Instead of "LINEA TRE" i see some squares and only 2 letters A and T; the proportions of these two letters A and T are also wrong, cause it should be a "narrow" font, but i see normal font.
For clarity i attach a screen capture of what i see.
File wrong dwf.gif is what i see in Composer (buggy text);
File right dwf.gif is what i see in DWF viewer (correct text)
Ty.
Ing. Luca Silvestri
Message 5 of 8
Luca,
Thanks for the clearer explanation of the problem you are seeing. There were some bugs fixed in the Viewer after Composer was released, so this is probably one of them. Its possible this was fixed in Composer's service pack 1, I'm not sure. You can download it from the Autodesk web site and try it out.
Message 6 of 8
I've already applied SP1 and the screenshots i've sent refer to Composer SP1.
build version of Composer is: 1.0.0.2161
Ty.
ing. Luca SIlvestri
Message 7 of 8
Luca,
As a developer, I have confirmed that this bug is fixed in a current build of Composer Release 2. The files RevInt 01.dwf and RevInt 02.dwf display the text as shown in the "right DWF.gif" image you supplied.
Message 8 of 8
Tim,
thank you for having taken care of my issue.
Looking forward to Composer 2.0 !
ing. Luca SIlvestri
