I'm trying to print from Design Review using "Current View" and I'm getting blank pages. When I use "Full Page" it prints fine, just not zoomed to the area I want to print. This is happening to me and several other people in my office.
I have tried changing the Scaling and Alignment settings, the paper sizes, advanced/color quality settings, and various printer properties, but nothing prints as long as "Current View" is set.
I also tried two different printers and Bluebeam PDF printer, and several different DWF files, all with the same result.
I have been able to print with "Current View" in the past, and the DWF files I'm using were updated recently. I can't say for sure that when the files were updated this issue started, but I can't think of anything else that has changed. Is it possible something in the files is interfering with this specific print setting? Is there some other cause?
Thank you for your question.
A similar defect had been logged. Once printing some kind of DWFx files with "Current View" setting, the position and scale of output might be incorrect.
If this is not your issue, please upload an example of a file to this thread for further investigate.
Please let me know if I can be of any further assistance.
The issue which reproduced only for DWFx file should have been fixed in ADR 2012.
Is your file published from Revit?
Could you please attach a test file for deep investigation?
Attached is the DWF file that will print blank pages when printing from the Current View. This error only occurs when printing the Current View and only seems to happen on certain pages (page 1 will print fine but page 14 is blank). This DWF file was created from Revit 2011 and is being viewed and printed from ADR 2012.
Please let me know if you need any other info.
Sam
we have issues with printing 2D sheets from 'Design Review' (2012 version,
and from both 32 & 64b. machines).
'Current View' from 'Print Range' section
in Print box doesn't work properly. When it is selected together with 'Fit
to page' option - sheets go out of printers completely blank (although Preview
shows correctly partial area).
When it is selected with 'Scale' option, we got message: Printing is Failed
('Full Page' option works ok)
All the files that we tried yesterday were made in ‘Revit’. We tried one dwf created from AutoCAD, seems to be working ok with 'Current View' plotting
Any ideas?
Nayamath
It's been over a year since I started this thread so I don't remember what file I was using, but it was generated from an AutoCAD DWG by a space database server we use called Drawbase Workplace Manager.
This is still an issue we are having, but it is intermittent. It happens relatively rarely and I haven't been able to identify any pattern. Some files will fail to print one day, and work another.
The next time it happens I will post the file to this thread.
We had already start investigation of issue which caused by DWF from Revit.
If your file is not published from Revit and still encounter this issue, please attach your file to this thread for deep investigation.
I am having a similar issue. I have a DWF that I am unable to print the view. It just prints blank pages. I can print the entire sheet with out any problems it just doing the view I have issues. I attached one of the files giving me the issue. Thanks for any help
We are expeirncing this with ADR 2012 with a DWF created from Revit. Any update? I have applied the lastest hotfix but we are still getting blank pages when printing the current view...
Could you please download the ADR 2013 Beta version to check if your issue is fixed?
Please sign up the ADR Beta Forum to download and install the Beta version.
