Design Review
Design Review
New Member
0 Kudos
Post 11 of 27
Re: Autodesk Design Review installation fails
09-17-2013 08:18 AM in reply to: jcclq
Thank you very much, it worked !
Regards.
Céline
Member
0 Kudos
Post 12 of 27
09-23-2013 07:23 AM in reply to: CélineRick
This link works:
http://download.autodesk.com/akdlm/esd/dlm/designreview/2013/enu/SetupDesignReview2013_bundle.exe
It is a big file, but it is worth the download.
1 Kudo
Post 13 of 27
09-30-2013 07:25 PM in reply to: heinsite
Hi Autodesk,
The problem is still there, kindly fix it even though the solution suggested is worked. Thanks.
0 Kudos
Post 14 of 27
10-10-2013 03:32 AM in reply to: skhuam
Unfortunatly i'm facing same issue with my customers ! this Design Review application was one of advantages to workwith our customers who have not Inventor or Autodesk's softwares.... unfortunatly it doesn't work... and thus customers asked: "you cannot use E-Drawing ?" ... thus, i try it, could convert using E-drawing Publisher (free) but without possibility to use measurment function, which is key to work with customer easily....
Autodesk Design Review is working on my computer (thanks to Inventor Suite), but not working to my customer computer and some collegues' computers... and i cannot ask my customer to use all tricks in this forum to fix the issue... customer needs easy and reliable solution !
To solve this issue, fortunatly we have an old Solidworks licence : i converted my assemby parts (from IAM to STEP) onto Solidworks, then created E-drawing data with measurment option actived; my customer could simply read and measure this E-drawing with free and working E-drawing Publisher...
> Results : we could work but i loosed 3 days trying to find an adequate solution to exchange with my customer.
To Autodesk : pls fix this issue asap as this Design Review is a very nice tool to work with our customers !
Member
0 Kudos
Post 15 of 27
10-10-2013 04:41 AM in reply to: lima_david
0 Kudos
Post 16 of 27
10-10-2013 05:14 AM in reply to: jcclq
My Autodesk dealer Support gave me the link this morning !!!... i got no time yet to try it... probably tomorrow i will try with my collegues.
I'lll keep you advised.
In any case, it takes 2 hours to download it and not shure my customer will accept to work with....
Member
0 Kudos
Post 17 of 27
10-10-2013 05:27 AM in reply to: lima_david
Just send a CD to your customer...
New Member
0 Kudos
Post 18 of 27
11-05-2013 11:37 AM in reply to: lordfarqad
Autodesk needs to fix this.
Two solutions worked for me:
1.) Before attempting to install Autodesk Design Review 2013, preinstall the Akamail NetSession Installer from here:
http://client.akamai.com/misc/demos/InstallationPopUp.html.
There is a link on that page, "download the installer," which will download "installer.exe" which is only about 10MB.
OR
2.) Download and install:
This file is huge (780 MB?) and takes a long time, but works.
0 Kudos
Post 19 of 27
11-06-2013 08:39 AM in reply to: CélineRick
In final, i continued to use the trick using Solidworks & E-drawing, as E-drawing is common tool for my customer and he was reluctant to download big file during hours...
Thank you for the links but i'm desapointed for Autodesk Design Review : only Autdesk Suite customers can use it easily.
Member
0 Kudos
Post 20 of 27
02-01-2014 12:49 PM in reply to: CélineRick
This is a constant pain.  Normally the bundle works. As part of the instructions we ask the customer to download the executable to their hard drive.
I need help resolving the following two issues:
First issue:
ADR 2013 fails with error 'not able to connect': The bundle has been installed and reinstalled several times in a Win7 OS machine, in the users %temp% ADRInstall.log shows 12 failures like this one:
2014/1/31:16:19:25          chamman            XXXMMAN-MOBL1        Uninstall              {8D20B4D7-3422-4099-9332-39F27E617A6F}  Failed
At the end it appears that the product installed properly, however customer is unable to run the program:
2014/1/31:16:19:57         chamman            XXXMMAN-MOBL1        Install    Autodesk Design Review 2013   Succeeded
any ideas how can I resolve this issue?  Please send me instructions as soon as you can.
Second issue:
Problem: useless link to update ADR 2013 product.
Issue:
First time user runs the program, the 'Autodesk Design Review Information' window pops-up on the screen.
New Autodesk Design Review information is available.
Get it now takes customer to [http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9338138]  Please try it.
Q. What is the action required in this page?  It used to be a link to upgrade the product, but I don't even find ADR 2013 in the list of products. I reported firt back in Nov.  Is there plans to correct this issue?
