Design Review
Design Review
Employee
herbert.he
Message 1 of 26 (51,050 Views)
Autodesk Design Review 2013 is now available for download!
51050 Views, 25 Replies
03-28-2012 06:16 PM
Hi Folks,
Autodesk Design Review 2013 is now available for download from our website!
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Active Member
justinpcarr
Message 2 of 26 (51,031 Views)
Re: Autodesk Design Review 2013 is now available for download!
03-29-2012 04:41 AM in reply to: herbert.he
Hi, can't seem to download the software though the installer program (had the same problem with ADR 2012). Keep getting "(0x2: Failed to download component.) Tried without Trent Micro Client running, no joy. Is there a link to manually download an .msi file for this please?
Thanks.
Employee
herbert.he
Message 3 of 26 (50,991 Views)
03-30-2012 06:02 PM in reply to: justinpcarr
Thank you for your feedback.
Download .MSI file from here and read the Installation Guide.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
greggbehmer
Message 4 of 26 (50,894 Views)
04-02-2012 11:26 AM in reply to: herbert.he
I'm getting an installation failed error using the exe file.  The following failed to install:
Autodesk Design Review 2012 (0x0: Internal Error)
I have Windows 7  Professional 64-bit OS.
I had ADR 2012 installed and functional.  As part of the 2013 install it uninstalled 2012, but ultimately the installation failed.  Screenshot attached.
Active Member
justinpcarr
Message 5 of 26 (50,884 Views)
04-02-2012 12:06 PM in reply to: herbert.he
Many thanks for the link. Software installed perfectly.
Thanks again
JP Carr.
greggbehmer
Message 6 of 26 (50,781 Views)
04-03-2012 12:02 PM in reply to: herbert.he
It looks like the msi install worked for me too.
Active Member
alanwooldridge5045
Message 7 of 26 (50,492 Views)
04-06-2012 03:52 PM in reply to: herbert.he
Well I tried it off the back of Autodesk Revit structural suite 2013 from the subscription and it installed with errors, I un-installed and tried to re-install and it just keeps telling me to check my internet connection. Typical buggy Autodesk software.
Any bright spark have any idea how to get this thing to install?
See http://cadalot-revitlearningcurve.blogspot.co.uk/2012/04/errors-installing-revit-structure-2013.html
Employee
herbert.he
Message 8 of 26 (50,356 Views)
04-10-2012 01:43 AM in reply to: alanwooldridge5045
Thank you for your question.
Regarding to the error "0x2: Failed downloading component.", it's probably because the improper "Downloads" security setting in Internet Zone. Please refer to the reply from p_younker in the thead http://forums.autodesk.com/t5/Autodesk-Design-Revi​ew/Can-t-install-Design-Review-in-any-WinXP-32/td...
Hope that helps.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Active Member
alanwooldridge5045
Message 9 of 26 (50,345 Views)
04-10-2012 02:46 AM in reply to: herbert.he
Thank you for the swift reply although it does not answer the question re the corrupt graphics file when installing off the Revit Structure Suite download as on my blog site.
However your link gives me a page not found error
Employee
herbert.he
Message 10 of 26 (50,341 Views)
04-10-2012 02:53 AM in reply to: alanwooldridge5045
Correct above invalid link here.
One another discussion group focuses specifically on Revit Structure. I suggest that you can post your question in that group.
Please try the following link for your convenience.
Autodesk Revit Structure
Any further question please let me know.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
