I initially recieved a Windows C++ 2008 redistributable error then a Visual studio 2010 c++ redistributable error now i get the above error. I have installed both 2012 Design review and Trueview successfully on a Windows 7 pc but on this XP Pro SP 3 pc which was running Design Review 2010 just fine i'm having all kinds of trouble. Interestingly enough 2012 Trueview installed with no issues on this XP pc. I have followed the uninstall previous versions of design review to the letter and am still having no luck getting it installed. i have verified in installed programs that i have;
Visuall c++ 2005 redistributable
Visual C++ 2008
Visual C++ 2010
and netframework 4.0
Thank you for reporting this issue.
Could you please attach the log file to this post for deep investigation?
The log file "SetupADR2012.log" should exist in the folder C:\DOCUME~1\username\LOCALS~1\Temp\AutodeskDesignReview2012logs\.
I was able to install it using the second manual installation method of downloading the entire executable installer file and running through the setup. For some reason the bootstrap installer wouldn't work.
