I have a multipage DWF file which when created from AutoCAD LT 2008 retains the filename of the drawings it was published from. These are then used as the sheet names within the new DWF file.
If I then print from the new DWF file to PDF I would still like it to retain these sheet names within the new PDF file but it would appear that they are replaced with sheet 1, 2, 3 etc.
Does anyone know how to retain this information when printing from DWF to PDF?
Solved by pendean. Go to Solution.
