when opening an dwg drawing with ADR 2012 the dwf file is different as far as thicknes of lines anf fonts is concerned - see example attached.
is there any possibility to keep the dwf file same as oryginal dwg file.
Thanks an advance for any help,
best regards,
BolekG
Thank you for your reply.
We haven’t found the issue on our DWG files; so please attach one of you case DWG files to this thread, which can help us better to research.
Hi Silvia,
thankyou for your email,
please find attached dwg drawing causing problem with ADR 2012 mentioned in my previous email.
Best regards,
BolekG
