I have been trying to install ADR 2012 and I always receive error message.
I run on Window 7 Professional and 64 bits
I have running (with no problems) Revit 2012, Robot 2012, and Autocad 2012
I had already tried the following:
- install from the website
- download and install from the computer
- download the bundle and install from the computer
- uninstall Akami and tried again..
Attached you find the log and error message
Gustavo Vasconcellos
Solved by wube. Go to Solution.
Thank you for your question.
According to the log file, your problem may be caused by Microsoft Visual C++ 2010 Redistributable (x86) upgrading. We are handling this problem.
You can work around this problem by remove Microsoft Visual C++ 2010 Redistributable (x86) from Control Panel->Add or Remove Programs. Then restart the installation process.
