Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
ADR failed install
3 REPLIES 3
1329 Views, 3 Replies
ADR failed install
Trying to install ADR 2010, I had 2012 or 13 on this machine previously and installed it, but now when I try to install I get a 0x658: internal error message, any thoughts?
3 REPLIES 3
Solved,
after uninstalling multiple times and trying to reinstall i got the exe for the full instalation and ran it once but realized it did not install design review. i uninstalled everything extra it put in and tried to run the exe again and noticed there was an X on the design review stating that there was already a newer version installed. i did a quick search and found this : http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19165706&linkID=16831209 a removal tool that did the trick. even tho design review was not in the programs and fetures anymore there was still enough of it left to make the install fail.
Beware of PC Clean, it placed a virus on my PC which was very difficulet to remove.
The  Autodesk ADR remover looks like it will remove all of your 2013 Design Suiite and you can't single out ADR for removal
pendean
