When the Send Email function is used from Design Review the dwf file attached to the email is
renamed adding a path.
Example: Site1.dwf is renamed as C Users 123 AppData Local Temp Site 1.dwf when attached to a new email message when using the Send Email feature.
This is not a new problem it has been reported before and is somehow tied to a POP3 email issue.
I know there is a workaround. Not looking for yet another workaround, just an in product fix for this problem.
My system is Win 7 64 bit with Office 2010 pro with Outlook.
From Help: Email an Open DWF File from Design Review
You can email an open DWF file with the most current data to a customer. If new markups were added, the latest modifications are included, and you are prompted to save the DWF file.
WarningThe Send command is only available if the computer includes a MAPI-enabled email program, such as Microsoft® Office Outlook®. This feature may not be compatible with 64-bit operating systems.
Will this feature be made to be compatible with 64-bit systems?
Thank you.
