Design Review
Member
simpleuser1
Message 1 of 3 (954 Views)
ADR 2013 import dwg wrong page size
954 Views, 2 Replies
01-10-2013 04:22 PM
Recently tried Design Review 2013 and I cannot get the page sizes to work. the same file is loaded in TrueView 2013 and the file looks great, but when I load in design review, only a portion of the file is visible. There appears to be nothing I can do about this.  Please have a look at the pictures:
True View 2013 drawing view. seems OK
and the design review version of the file is here:
Design Review version not working
So you can see the letter size paper makes no sense. it is a D-size paper in true view. Model space is not much better.
Can someone help guide me to a solution?
TRUEVIEW is a DWG viewer.
ADR uses whatever plot parameters it finds in the layout your DWG file opens, generated a DWF, then displays it. It does not open and view a DWG file natively.
Please elaborate as ADR is not a good DWG file viewer if the DWG file is not actively set to behave as you wish it from AutoCAD.
pendean
Message 2 of 3 (945 Views)
Re: ADR 2013 import dwg wrong page size
01-11-2013 05:58 AM in reply to: simpleuser1
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
simpleuser1
Message 3 of 3 (939 Views)
01-11-2013 07:55 AM in reply to: pendean
Alright. So one has to apply the correct plot parameters within True-View and then export to DWFx. This seems to work now. Thanks!  Basically I think it was a problem with the DWG file not applying any plot parameters to the layout or model space elements. Thanks for the hint and solution. I now can mark up the page with an applied plot parameter.
Carl
