Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
ADR 2013 import dwg: No layers
4 REPLIES 4
stefan.kraft
2204 Views, 4 Replies
I have many dwg-files and have installed DWG True View 2013 and Design Review 2013. If I now open a dwg-File in Design Review direktly I do not get the layerinformations.
Whre do I have to change the settings so that in this automatic conversion of the dwg-files in dwf the layers will also be included.
4 REPLIES 4
pendean
in reply to: stefan.kraft
ADR does not open DWG files: it uses whatever DWG-capable app you have to do the conversion for you, with limitations.
If you want total control, use DTV and change/set the DWF printer to output layers before creating the DWF file: ADR may then default to that but you'll have to test and confirm.
stefan.kraft
in reply to: pendean
I tried this before in the printing settings in my DWG True View 2013. I have checked and changed the Custom Properties of the DWF6ePlot.pc3 and the DWFx ePlot (XPS Compatible).pc3 so both should include layer information.
But when I still open a dwg-file directly in Autodesk Design Review, the converted dwf-file does not include the layers.
pendean
>>>...open a dwg-file directly in Autodesk Design Review...<<<
Do it the long way then 😞 it's never been capable of translating DWG files to DWF on it's own. By design.
DTV has a publish feature you can use to convert a long list of DWGs to DWF properly. to fit your exact needs, if you don't have AutoCAD to do so.
antiartist
So Design Review uses it's own super-secret plotter for importing a DWG (or any other supported format), I take it?  Strange that it cannot be customized in any way.
The more I attempt to incorporate Design Review into our workflows, the more I wonder just what Adobe was thinking when they created this application.
