Design Review
Design Review
Member
panama2011
Message 81 of 155 (3,071 Views)
Re: ADR 2012 installation issue collection
06-12-2011 07:00 PM in reply to: JonRE
Good afternoon
I am having the same problem with ADR 2012, ( inetrnal error 0*643 ).
Am able to download but will not install on Windows XP, have you found a solution ?
Any help would be most appreciated.
Employee
wube
Message 82 of 155 (3,063 Views)
06-12-2011 08:42 PM in reply to: panama2011
Thank you for your feedback.
Please attach the log file to this thread for investigation.
SetupADR2012.log in the folder:
Windows 7
C:\Users\[your user name]\AppData\Local\Temp\AutodeskDesignReview2012Logs\
Windows XP
C:\Documents and Settings\[your user name]\Local Settings\Temp\AutodeskDesignReview2012Logs\
And please make sure you have admin access to run the installer.
Ben Wu
SW Engineer
PSEB-GE-ACRD
Employee
wube
Message 83 of 155 (3,062 Views)
06-12-2011 08:43 PM in reply to: JonRE
Windows 7
Windows XP
Ben Wu
SW Engineer
PSEB-GE-ACRD
Member
cpulsoni
Message 84 of 155 (3,055 Views)
06-12-2011 11:33 PM in reply to: panama2011
Hello Ben Wu
regards for your answer.
Yes I'm the admin. In attach the log required.
Claudio Pulsoni
Employee
wube
Message 85 of 155 (3,052 Views)
06-13-2011 02:08 AM in reply to: cpulsoni
Please try the following steps:
1. Download and install the Windows Installer Cleanup Utility.
2. Run the Windows Installer Cleanup Utility from Start/Programs, and remove all the detected versions of ADR.
3. Install ADR 2012.
Hope this helps.
Ben Wu
SW Engineer
PSEB-GE-ACRD
Member
JonRE
Message 86 of 155 (3,032 Views)
06-13-2011 03:09 PM in reply to: panama2011
Here is the log file.
Employee
wube
Message 87 of 155 (3,024 Views)
06-13-2011 09:35 PM in reply to: panama2011
Could you please check if you can modify the register value at HKEY_LOCAL_MACHINE\Software\Classes\.dwfx\PersistentHandler manually?
Thank you
Ben Wu
SW Engineer
PSEB-GE-ACRD
Member
cpulsoni
Message 88 of 155 (3,002 Views)
06-15-2011 03:15 AM in reply to: panama2011
 Hello Ben Wu,
I cleaned the register and now ADR12 running very well.
Best regards for your immediatly and professional support this is one of reason why i continue to use autocad.
best  regards
Claudio Pulsoni
New Member
jmadk
Message 89 of 155 (2,963 Views)
06-21-2011 10:42 AM in reply to: cpulsoni
I have trouble with installer complaing about VC++ runtimes, and I am running the full installer version - SetupDesignReview2012_bundle.exe.
I have attached installer log and screenshot of the runtimes that are already installed on my Win7 SP1 x64.
Thank you.
New Member
jmadk
Message 90 of 155 (2,959 Views)
06-21-2011 11:12 AM in reply to: jmadk
Well, I figured that ADR was looking for a specific version of some VC++ runtime, and Windows perhaps was not letting ADR to install it because a newer version was already in the system.
What I just did is, that I uninstalled every VC++ runtime I had, and let ADR have its day.
I have attached screnshot which shows runtimes that were installed by ADR.
From what I can tell the problem was that I already had VC++ 2010 v10.0.40219 installed (this is VC++ 2010 SP1) but ADR wanted to have an older VC++ 2010 v10.0.30319.
It would be nice if this issue would be fixed for a future version(s) of installer, so that ADR would not demand older version of a runtime which Windows does not let to install.
