Design Review
Design Review
New Member
johnsoap
Message 41 of 155 (6,217 Views)
Re: ADR 2012 installation issue collection
04-15-2011 07:12 AM in reply to: dickyshu
This isn't an installation issue - it installed just fine, but I am not able to edit the size of text boxes after creating them.  When I click on the text box, the yellow "grab" points come up, but I am only able to drag the entire box and not able to stretch or edit the shape of the text box.
All other shapes and mark-ups are working correctly.
Employee
dickyshu
Message 42 of 155 (6,196 Views)
04-17-2011 07:25 PM in reply to: johnsoap
That may caused by "No Border" option checked.
Please uncheck the "No Border" option, and you will be able to edit the shape of the text box.
Please refer to attached image.
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
New Member
johnsoap
Message 43 of 155 (6,186 Views)
04-18-2011 07:17 AM in reply to: johnsoap
Ok, this worked.  This was not an issue for previous versions of ADR.
Active Member
everettm
Message 44 of 155 (6,159 Views)
04-21-2011 03:43 PM in reply to: wube
Now stalls again after installing .NET 4.0 from Microsoft when trying to install design review.
Tried the same method to install manually but get error.  I unzipped ADR manually but it had an error.
See screen shot.
Why all these problems on my laptop but was installed without issue on my desktop?
thx
Employee
wube
Message 45 of 155 (6,140 Views)
04-26-2011 06:23 PM in reply to: everettm
Please copy the cache files from your desktop to your laptop.
Unzip the Design Review SetupDesignReview2012.msi.zip to a temp folder.
And install Design Review manually by Double Click the msi file.
Ben Wu
SW Engineer
PSEB-GE-ACRD
New Member
raygbmw1
Message 46 of 155 (6,129 Views)
04-26-2011 10:58 PM in reply to: dickyshu
I can't install ADR it keeps giving me the attached screen and reffering me to autodesk website. What can I do?
Member
paul010uk
Message 47 of 155 (6,118 Views)
04-27-2011 04:02 AM in reply to: johnsoap
I have the same issue as raygbmw1, install fails on Visual Studio Runtime with 0x0: Internal Error
the log from C:\Documents and Settings\username\Local Settings\Temp\AutodeskDesignReview2012Logs says:
"Installing Visual Studio 2008 SP1 C++ Runtime
!!!Failed to install, unrecognized extension"
It doesn't get any further than that. Checking Add/Remove Programs in Control Panel shows Microsoft Visual C++ 2008 Redistributable is already installed.
I'm trying to install on a Sony Vaio VGN-BZ11MN laptop running XP SP3
Active Member
everettm
Message 48 of 155 (6,105 Views)
04-27-2011 07:38 AM in reply to: wube
Finally working.
Thanks!
Distinguished Contributor
Doug_000
Message 49 of 155 (6,097 Views)
04-27-2011 10:07 AM in reply to: everettm
Hi, I downloaded AutodeskDesignRevSetup.exe. When I atempt to run it, I get (0x2: Failed downloading component.)
Employee
dickyshu
Message 50 of 155 (6,080 Views)
04-27-2011 06:38 PM in reply to: raygbmw1
The picture you attached demostrates VS2010 C++ Runtime install failure.
Could you please go to "C:\program files (x86)\common files\akamai\Cache" (Windows 7) to find VS2010 C++ Runtime installer and run it manually?
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
