Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
ADR 2012 installation issue collection
155 REPLIES 155
Message 1 of 156
dickyshu
20318 Views, 155 Replies
It has come to our attention that a small number Autodesk Design Review users have been having issues with installing the latest version-ADR 2012 from our website.
We post this message in order to collect the installation issue you've encountered, which will help us to track & resolve these problems. You also can refer to some probelm solutions that are same to your case.
Please kindly write information with below items:
  1. What is the problem you met about installation?
  2. Your OS platform(WinXP, Vista or 7) (32 or 64bit).
  3. Reproduce steps.
  4. It's better to have a screenshot if convenient.
-Autodesk Design Review Development Team
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Autodesk, Inc.
155 REPLIES 155
Message 21 of 156
jonfossum
in reply to: dickyshu
Hi
can't install 2012 version om my computer. the default chooises are grey and i can't puch install button
I have tryed several times with same result
OS w7 64 bit English
DWG TrueView 2012
Message 22 of 156
dickyshu
in reply to: jonfossum
Thank you for posting.
From the snapshot you attached, we've noticed that DWG Trueview 2012 has been installed before, so that the installer blocks your attempt to install again.
Please go to program files folder to check if that application exists.
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Autodesk, Inc.
Message 23 of 156
wube
in reply to: everettm
Please make sure you get admin right to run the ADR2012 installer.
You screen shot show that VS2010 C++ Runtime had download completed.
Please quit the installer application and run the VS2010 C++ Runtime installer manually.
The VS2010 C++ Runtime installer should exist in C:\Program Files\Common Files\Akamai\Cache\37309\.
If install succeed, run the ADR2012 installer again.
Thank you
Ben Wu
SW Engineer
PSEB-GE-ACRD
Autodesk, Inc.
Message 24 of 156
jonfossum
does not exist
Message 25 of 156
jonfossum
Trueview do exixt in the program folder
Message 26 of 156
everettm
in reply to: wube
Yes, I have admin rights.
I followed your instructions and installed the C++ manually with no problem.
Then back to download and had the same stall after downloading Microsoft .NET 4.  See attached screen shot.
Please help.
Thanks!
Message 27 of 156
jandrews407
I am having same issue.  Cannot install ADR 2012.
OS = XP 64 bit
Any solutions yet?
Message 28 of 156
dickyshu
in reply to: jandrews407
Please provide more details:
  • Describe what's going on while installing
  • Capture a screenshot
  • Attach SetupADR2012.log file (C:\Documents and Settings\[your user name]\Local Settings\Temp\AutodeskDesignReview2012Logs)
So that we can help you to diagnose the problem.
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Autodesk, Inc.
Message 29 of 156
march_bim2
I've had the attached error all day.  First on my laptop which is 32bit and now on my desktop which is 64bit.  Please help.
Message 30 of 156
dickyshu
in reply to: march_bim2
From the screenshot, I guess you've downloaded DWG Trueview 2012 standalone installer.
ADR 2012 bootstrap installer will not show DWG Trueview 2012 install UI, maybe you can turn your question to DWG Trueview forum, there you will get answered:
http://forums.autodesk.com/t5/DWG-TrueView/bd-p/109
Thank you!
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Autodesk, Inc.
Message 31 of 156
jandrews407
Dicky,
I am trying to install ADR 2012.
I run AudtodeskDesignRevSetup.exe whoich I have downloaded.
Installation begins and stops saying Installation Falled. Autodesk Design Review 2012 (0x643: internal error) (See attached)
Message 32 of 156
jonfossum
Hi
don't know what happend. But i tryed all over again. and downloaded from http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=12423405
it all vent quite well. It works.
microsoft ghost Smiley Very Happy
Message 33 of 156
rmwillsie34
I was able to install 2012 after several tries but it does not work properly.
I have Windows XP and IE7 and using Adobe X standard.
My problems are:
1. ADR opens a files on my computer and our local server, but I cannot create pdf files from any of the dwf's.  ADR just hangs and I eventually have to go to task manager to close out of ADR.  Is there an issue with Adobe X?
2. When I try to open a dwf from an ftp site, I get the error message shown in the attached file and nothing opens.
I never had a problem with 2009 or 2010.  Unfortunately, I cannot download the 2010 from your website.
Message 34 of 156
wube
Thank you for sending us the screen shot and log file.
The log file show that msiexec failed to install Design Revew.
Please unzip the file "c:\program files (x86)\common files\akamai\Cache\37309\SetupDesignReview2012.msi.zip" to a temp folder, and there should be a SetupDesignReview2012.msi file in the folder. Double click it to install Design Review2012 manually.
Please let me know if it doesn't works.
Ben Wu
SW Engineer
PSEB-GE-ACRD
Autodesk, Inc.
Message 35 of 156
wube
The screen shot show the .Net component had downloaded complete.
Please go to C:\Program Files\Common Files\Akamai\Cache\37309\ and install the .Net component manually.
Thank you
Ben Wu
SW Engineer
PSEB-GE-ACRD
Autodesk, Inc.
Message 36 of 156
everettm
in reply to: wube
Get an error when I try that.
See attached.
Thanks!
Message 37 of 156
jandrews407
in reply to: wube
Ben,
This worked, however there was an error. (see attached).  ADR seems to be working.  I also needed to install Browser Add-on and TrueView seperately.  Is this the only solution?
Message 38 of 156
wube
Please restart AudtodeskDesignRevSetup.exe. The application will download and install Browser Add-on and TrueView automatically for you.
Thank you
Ben Wu
SW Engineer
PSEB-GE-ACRD
Autodesk, Inc.
Message 39 of 156
wube
Please try the following steps.
1. Delete dotnetFx40.exe in the ...\Akamai\Cache\37309 folder.
2. Start AutodeskDesignRevSetup.exe.
3. If the application stall at downloading .Net Framework 4.0 and .Net Framework 4.0 had been downloaded complete, please quit AutodeskDesignRevSetup.exe and run dotNetFx40.exe in the Cache\37309 folder again.
If dotNetFx40.exe still failed to install, Please download .Net Framework 4.0 from http://www.microsoft.com/net/ and install it manually.
4. Restart AutodeskDesignRevSetup.exe again after .Net Framework 4.0 installed.
Ben Wu
SW Engineer
PSEB-GE-ACRD
Autodesk, Inc.
Message 40 of 156
jandrews407
in reply to: wube
So the solution is to unzip SetupDesignReview2012.msi​.zip, install using SetupDesignReview2012.msi​, restart AutodeskDesignReSetup.exe to finish off installation.
