Design Review
Design Review
Member
0 Kudos
Post 21 of 155
Re: ADR 2012 installation issue collection
04-08-2011 12:50 AM in reply to: dickyshu
Hi
can't install 2012 version om my computer. the default chooises are grey and i can't puch install button
I have tryed several times with same result
OS w7 64 bit English
DWG TrueView 2012
Employee
0 Kudos
Post 22 of 155
04-08-2011 12:57 AM in reply to: jonfossum
Thank you for posting.
From the snapshot you attached, we've noticed that DWG Trueview 2012 has been installed before, so that the installer blocks your attempt to install again.
Please go to program files folder to check if that application exists.
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Employee
1 Kudo
Post 23 of 155
04-08-2011 01:34 AM in reply to: everettm
Please make sure you get admin right to run the ADR2012 installer.
You screen shot show that VS2010 C++ Runtime had download completed.
Please quit the installer application and run the VS2010 C++ Runtime installer manually.
The VS2010 C++ Runtime installer should exist in C:\Program Files\Common Files\Akamai\Cache\37309\.
If install succeed, run the ADR2012 installer again.
Thank you
Ben Wu
SW Engineer
PSEB-GE-ACRD
Member
0 Kudos
Post 24 of 155
04-08-2011 03:33 AM in reply to: jonfossum
does not exist
Member
0 Kudos
Post 25 of 155
04-08-2011 03:34 AM in reply to: dickyshu
Trueview do exixt in the program folder
Active Member
0 Kudos
Post 26 of 155
04-08-2011 07:43 AM in reply to: wube
Yes, I have admin rights.
I followed your instructions and installed the C++ manually with no problem.
Then back to download and had the same stall after downloading Microsoft .NET 4.  See attached screen shot.
Please help.
Thanks!
2 Kudos
Post 27 of 155
04-08-2011 10:37 AM in reply to: dickyshu
I am having same issue.  Cannot install ADR 2012.
OS = XP 64 bit
Any solutions yet?
Employee
0 Kudos
Post 28 of 155
04-10-2011 06:56 PM in reply to: jandrews407
Please provide more details:
  • Describe what's going on while installing
  • Capture a screenshot
  • Attach SetupADR2012.log file (C:\Documents and Settings\[your user name]\Local Settings\Temp\AutodeskDesignReview2012Logs)
So that we can help you to diagnose the problem.
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
New Member
0 Kudos
Post 29 of 155
04-10-2011 07:03 PM in reply to: jonfossum
I've had the attached error all day.  First on my laptop which is 32bit and now on my desktop which is 64bit.  Please help.
Employee
0 Kudos
Post 30 of 155
04-11-2011 01:11 AM in reply to: march
From the screenshot, I guess you've downloaded DWG Trueview 2012 standalone installer.
ADR 2012 bootstrap installer will not show DWG Trueview 2012 install UI, maybe you can turn your question to DWG Trueview forum, there you will get answered:
http://forums.autodesk.com/t5/DWG-TrueView/bd-p/109
Thank you!
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
