Hello everybody,
l have been looking for a solution of the problem below but without any success yet. đ
When I ran from command line the command: designreview "blabla" the design review opens the dwf file "blabla"
but I am not able to
tell the design review to show me a named view.
It is quite simple in an autocad: acad "blabla" /v "view1" gives required result.
Unfortunately, the design review does not know the switch /v .
Any suggestion to solve this problem?
Thanks a lot in advance.
Best regards.
Ales Stanek
Thank you for your question, Ales.
At present ADR does not support this feature. Usually there is an initial view used to control the first scenario after DWF file loaded. The initial view is published from those applications like AutoCAD, Revit, etc. You can set proper publishing options through these applications to fulfill this requirement.
Hello Mr. Tank,
I found solution for this problem.
"designreview.exe blabla.dwf?view=view1"
Best Regards
Ales Stanek
