Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
ADR 2011 - VB.net - Windows 7 64-bit Crash
8 REPLIES 8
Message 1 of 9
jhargett
1849 Views, 8 Replies
I am developing a program to automate ADR using VB.net. I have a simple test case that that can be install on my Windows XP 32 bit system and it works fine. It is just one form with the ADR control embedded in it. When I install this on a Windows 7 64-bit system, it crashes with the message below:
Description:
  Stopped working
Problem signature:
  Problem Event Name:	CLR20r3
  Problem Signature 01:	adrtest.exe
  Problem Signature 02:	1.0.0.0
  Problem Signature 03:	4dac6793
  Problem Signature 04:	ADRTest
  Problem Signature 05:	1.0.0.0
  Problem Signature 06:	4dac6793
  Problem Signature 07:	e
  Problem Signature 08:	ef
  Problem Signature 09:	System.InvalidOperationException
  OS Version:	6.1.7601.2.1.0.256.48
  Locale ID:	1033
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
Any ideas on how to fix this?
8 REPLIES 8
Message 2 of 9
herbert.he
in reply to: jhargett
Thank you for reporting this issue.
I cannot get cule from your message above. Could you please share a sample application for reproducing this problem for us to investigate?
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
Message 3 of 9
jhargett
Attached is the entire Visual Basic program that reproduces the problem. I am using Visual Studio 2005.
Message 4 of 9
herbert.he
Thank you for your feedback.
Please set "Solution Platforms" as "x86" and build your program again.
Hope that helps.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
Message 5 of 9
jhargett
in reply to: herbert.he
When I target the compile for x86 and create an install program and try to install it, I get an error during install. It fails to register a dll.
Message 6 of 9
herbert.he
Actually, you do not need to register AdCommon.dll with your installer, this DLL has been registered with Autodesk Design Review installation. Please revise your installer and try it again.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
Message 7 of 9
jhargett
I removed references to DLLs from ADR, and I target the compile to x86. I ran the install program on my Windows XP 32 bit box, and it installed correctly and the program ran. It showed the ADR control on the VB form. When I install this same program on the Windows 7 64-bit box, it installs correclty, but when I run it, it crashes and I get this error:
Description:
  Stopped working
Problem signature:
  Problem Signature 01:	adrtest2.exe
  Problem Signature 03:	4ebac30e
  Problem Signature 04:	ADRTest2
  Problem Signature 06:	4ebac30e
  Problem Signature 08:	e9
  Locale ID:	1033
I have attached the entire VB.Net project.
Jon
Message 8 of 9
herbert.he
I installed your application on my Windows 7 64-bit machine and the program ran. To run your program, the machine still needs ADR installed.
Attach the installer I used.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
Message 9 of 9
jhargett
Yes, Of course ADR is installed. It must be a problem with just this Windows 7 box. I will try to figure out what is going on.
Jon
