Design Review
Design Review
Board Manager
7 Kudos
Post 51 of 73
Re: ADR 2011 - Suggested Fixes for Installation-Related Issues
03-02-2011 10:50 AM in reply to: djskipper
What shortcut do you mean?
C.
Chris Blocher
Principal Learning Content Developer
Cloud Platforms
Member
0 Kudos
Post 52 of 73
03-02-2011 10:53 AM in reply to: cblocher
You could try downloading the "bundle" from here:
http://www.autodesk.com/designreview-download-netw​ork
Dennis
Board Manager
7 Kudos
Post 53 of 73
03-02-2011 10:56 AM in reply to: djskipper
Ah, thanks for the tip, Dennis. Here's the "correctly formed" link:-)
http://www.autodesk.com/designreview-download-network
Best,
C.
Chris Blocher
Cloud Platforms
0 Kudos
Post 54 of 73
03-02-2011 11:02 AM in reply to: cblocher
Any news on yesterdays information:
Orlando rosario
Attached is the requested File.
Thanks for all your help.
Orlando Rosario
0 Kudos
Post 55 of 73
03-02-2011 01:14 PM in reply to: cblocher
There's a possible theory to this problem, it could very well be my logon profile to the network.
I had the administrator log in and then installed the ADR 2011 and DWG Truview 2011, both worked like a charm.
Thanks to All;
Orlando Rosario
Board Manager
7 Kudos
Post 56 of 73
03-02-2011 01:20 PM in reply to: cblocher
Hi Orlando,
Are you all set then? Everything installed and working?
C.
Chris Blocher
Cloud Platforms
0 Kudos
Post 57 of 73
03-03-2011 04:52 AM in reply to: cblocher
Everythings Up and running.
Thanks Again;
Orlando
0 Kudos
Post 58 of 73
03-15-2011 11:34 AM in reply to: cblocher
I've been trying unsuccessfully to install Design Review for 4 hours now.  I am attempting to run the msi on a Windows 7 Service Pack 1 (64-bit) machine.  I get this message:
"Error 1723. There is a problem with this Windows Installer package.  A DLL required for this install to complete could not be run. Contact your support personnel or package vendor. Action _560A25DD_C4DE_4BC1_92AD_536652FFBE95, entry: Uninstall, library: C:\Program Files (x86)\Autodesk\Autodesk Design Review\UPI\UPICA.dll"
In case you cannot see the image I tried to paste from Alt/PrtScn
I am also attaching the msi installer log generated by this failed installation attempt.
Help please, this is the first of 11 new workstations that need to be set up with Revit MEP.  I'd like to create an image.
Member
0 Kudos
Post 59 of 73
10-29-2011 07:34 AM in reply to: cblocher
I am having the exact same problem as above. Please help!
New Member
0 Kudos
Post 60 of 73
Re: ADR mobile
02-01-2012 12:07 PM in reply to: cblocher
I've got ADR mobile on my iPad. Have loaded DWF's from revit onto the cloud. Can see the files but can't view them. Tried re- loading, tried shouting at it - all to no avail. Any advice?
