Design Review
Active Member
alexs
Message 11 of 14 (1,177 Views)
Re: ADR 2011 Api & VB2010 Express
03-06-2012 02:22 PM in reply to: vgottipa
Yes. The targeted environment is x86 and .Net Frameworks 3.5.
Has anybody managed to successfully use the DWF Viewer Control with VS2010? If so, what did the trick?
By the way I am using VS2010 Ultimate with SP1 on the Windows 7 Professional.
Alex
Valued Contributor
FRFR1426
Message 12 of 14 (1,073 Views)
10-08-2012 06:48 AM in reply to: alexs
Old thread, but if it can help someone. I've managed to get it works:
  1. Open a console and browse to C:\Program Files (x86)\Common Files\Autodesk Shared\DWF Common\ ;
  2. Run aximp.exe AdView.dll. Two files are generated: ExpressViewerDll.dll and AxExpressViewerDll.dll ;
  3. Add the AxExpressViewerDll.dll as a reference to your VS solution ;
  4. In the load event of your form, create the control by code:
var aev = new AxExpressViewerDll.AxCExpressViewerControl();
Controls.Add(aev);
aev.Dock = DockStyle.Fill;
Valued Contributor
andred
Message 13 of 14 (414 Views)
02-18-2014 10:54 AM in reply to: FRFR1426
I'm trying your solution but I was not able to extract axExpressViewerDLL.dll. There is no registered Activez Control found in adview.dll.
André
nstone
Message 14 of 14 (133 Views)
09-10-2014 05:17 PM in reply to: andred
You still need to build the solution with .net 3.5 framework and a platform target x86
and this worked for me.
