Design Review
Design Review
Distinguished Contributor
12 Kudos
Post 1 of 14
ADR 2011 Api & VB2010 Express
3526 Views, 13 Replies
02-01-2011 04:12 AM
Hi
I have a problem, when I try to Insert  the Autodesk DWF Viewer Control.
in a form.  VB 2010 Express is crash immediately.
René J
Employee
2 Kudos
Post 2 of 14
Re: ADR 2011 Api & VB2010 Express
02-11-2011 07:17 PM in reply to: Rene-J
Thank you for reporting this issue.
It seems like an issue of VS2010 rather than ADR. Please refer to this article:
https://connect.microsoft.com/VisualStudio/feedback/details/568769/aximp-error-with-vb6-activex-cont...
Please try to apply VS2010 hotfix-2066987 to resolve this issue.
Please let us know if it works.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
New Member
0 Kudos
Post 3 of 14
03-09-2011 06:55 PM in reply to: Rene-J
I am experiencing similar behavior with Visual Studio 2010 Professional.  I've applied the hotfix from Microsoft (2066987) and the same behavior continues.  I've attached a screenshot of the VS designer right before it crashes and has to be restarted.
Any ideas would be greatly appreciated.
Sincerely,
Dale Lundgren
Employee
2 Kudos
Post 4 of 14
03-11-2011 07:22 PM in reply to: dlundgren
Thank you for your question.
Since ADR 2011 required .NET 3.5 runtime, please insure to select Target Framework as .NET Framework 3.5 for your project.
Please let me know if you have any further question.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
New Member
0 Kudos
Post 5 of 14
03-14-2011 05:19 AM in reply to: herbert.he
I have the same problem with integration the ADR2011 in Visual Studio Premium via the COM component. I have checked several combinations:
- x86 or x64 machine with C# or VB .NET -> crashes in WIndows Forms Designer
- Framwork 3.5 or Framework 4.0 -> crashes in WIndows Forms Designer
- installing HotFix from MS Support KB2066987 -> same result
- installing Visual Studio SP 1 -> same result
So I didn't find a combination to integrate the ADR2011 in VS2010. Does anybody know what to to? The error is the same as described in the previous comments.
Regards
Jens
Valued Contributor
0 Kudos
Post 6 of 14
04-26-2011 03:18 PM in reply to: Rene-J
Same problem here using visual studio 2010 professional and c#.  Visual Studio crashes every time I try to add the viewer to the form.
Valued Contributor
0 Kudos
Post 7 of 14
07-21-2011 12:01 PM in reply to: gbneff
Has anyone found a solution to this issue?
I have the same problem with Visual Studio 2010 and ADR 2012.
I need help ASAP please someone!!! :smileyhappy:
New Member
0 Kudos
Post 8 of 14
07-21-2011 09:55 PM in reply to: jta_albert
Yes I have. My solution was to use Visual Studio 2008 with .NET Framework 2, build a DLL and use this DLL in your VS2010 project. This works fine.
Jens
Active Member
0 Kudos
Post 9 of 14
03-05-2012 08:38 PM in reply to: Rene-J
It seems to me, by reading the messages in this tread, which go back to over a year, that the situation with using the ADR 2012 with VS2010, has not changed.
I just started with developing an application that uses the RealDWG to create a set of drawings based on templates and change the values of attributed blocks. This part works fine. However, since that the RealDWG does not displays or prints out but it can save drawing files to the dxf format, I planned to use ADR to view and print out completed drawings.
So far I wasn’t able to use the Autodesk DWF Viewer Control with VS2010; VS2010 crushes immediately after inserting the control into a form. I then created a DLL using the VS2008, but it didn’t work. By the way, with VS2008, I have to use the .NET Framework 2.0 to make the programme works.
With no success in the above attempts, I created a line command for ADR to print out a specific file. It worked well with the DWF files but will not work with DXF files. This is unfortunate, since that the RealDWG SDK will not save DWG to DWF format.
Herbert He, the Autodesk SW Engineer, has made a comment stating that this seems to be a VS2010 issue rather than ADR. If this is so, I would like to see more specific or detailed explanation and conformation about ADR 2012 compatibilities with the VS2010, including a working sample, VB or C#.
If in the meantime if an updated ADR is available, please advice.
I am not a professional programmer, but if so many other users are reporting the same issue, I trust that it should not be ignored
Alex Seger
Engineering & Manufacturing Systems Specialist
Active Contributor
3 Kudos
Post 10 of 14
03-06-2012 07:49 AM in reply to: alexs
Did you try targeted to x86?
