Not running on El Capitan beta 2
GRSnyder
Message 1 of 50
GRSnyder
After updating my OS installation to OS X 10.11 "El Capitan" beta 2, Fusion 360 will no longer start up. It just shows an "application has encountered an unexpected authentication error and must be quit" message. Is this a known issue?
I did not install beta 1 of El Capitan, so I don't know if this issue is new with beta 2.
Please let me know if any additional information or logging would be helpful.
Replies (49)
Message 2 of 50
kris_berg
Hi @GRSnyder,
Thank you for posting. It is an issue we are aware of and we are working on a solution. I will repost as soon as we have a definitive date on when a solution will be available.
Thank you,
Kris Berg
Fusion 360 Development
Kris Berg
Senior Software Architect - Autodesk
Message 3 of 50
Hopefully as soon as possiple. I've to offer a Lasercutter workshop this weekend. ;o)
Otherwiese I've to switch to a Windows 8.1 running into a Parallels Desktop VM.
Message 4 of 50
kris_berg
Hi @Anonymous and @GRSnyder,
I will send you a private message on how to workaround the issue (temporarily) until we address the issue.  Note that there may be other issues with Fusion 360 and El Capitan Beta 2 as we have not finished verifying it on that OS.
Thank you,
Kris Berg
Kris Berg
Message 5 of 50
Hi, I'm having the same problem, if there is a workaround, please let me know.
Message 6 of 50
I've found a workaround for the latest version of El Capitan and Fusion 360 (June update).
http://forums.autodesk.com/t5/api-and-scripts/os-x-el-capitan-beta-issues/td-p/5690467
Kind regrads,
Markus
Message 7 of 50
Thank you very much! It at least allows me to work in online mode (somehow when I turn the wifi on it doesn’t allow me to work online, anyway, that’s the risk of beta testing…
Best regards
Amilcar
Message 8 of 50
It works! Thank you so much.
Message 9 of 50
Mowee
Hi, I'm having the same problem in El Capina Beta 3 (15A216g).
The workaround for turning off the network does let me run the app in offline mode, but I can not login and then it tellme me I have run in offline mode for to long and quits.  😞
Funny thing is I have never used Offline mode before?Screen Shot 2015-07-10 at 4.26.32 PM.png
Message 10 of 50
It's a mess with this beta 3 release. Currently, I've no workaround for this.
My only recommandation is:
1. Create a Yosemite USB Installer and than reinstall OS X.
2. Run Windows or Yosemite into a VM, like Parallels / VirtuialBox.
Otherwise, we have to wait for Autodesk's and Apple's developers to fix incapabilities.
Kind regrads
Markus
Message 11 of 50
kris_berg
Unfortunately we have not found a workaround to this problem.  We are working on the issue and I will update you when we have more information.
Thank you,
Kris Berg
Kris Berg
Message 12 of 50
Hi, I’m not sure if it’s at all related, but I have a gut feeling that this might be the problem. (from a purely lay perspective)
"When negotiating a TLS/SSL connection with Diffie-Hellman key exchange, OS X El Capitan requires a 1024-bit group or larger. OS X El Capitan will not connect to a server that allows negotiation with a 512-bit or smaller group.”
Again, I’m not sure if it helps at all, hopefully you will find a solution to the problem.
Best regards
Amilcar
Message 13 of 50
@Anonymous
I have also read about this. That might be possible but didn't explain why the AppStore Version isn't also working. I'n my experience, Apple is caring about the compatibility of allready approved Mac / iOS AppStore Apps.
-- Markus
Message 14 of 50
Message 15 of 50
Mowee
Yosemite version 10.10.4 is listed as requiering the new minimum Diffie-Hellman key exchange group size of 2048 bits and Fusion 360 works as expected.
So I guess thats not the issue.
Message 16 of 50
Yosemite 10.10.4 was released on Jun 30, 2015. Have you been already updaded?
In case, this doesn't cause those erros, what else could it be? It's pretty annoying.
Message 17 of 50
Mowee
I have been using 10.10.4 since it's first beta version and never had an issue with Fusion 360 on it.
I only just put El Capitan beta on my laptop satering with Beta 2 to test for issues like this.
Message 18 of 50
macmanpb
I dont understand, who is installing a new desktop system in beta status on a productive system.
This is not clever!
Message 19 of 50
Mowee
Not sure anyone here is???
Message 20 of 50
I still guess, that's an authentification process error and the TLS/SSL systemwide policy change could explain why Fusion 360 would start in offline mode and get an auth error at startup.
Last but not least, Autodesk whole website is buged with SSL errors / bad practices.
Litle note: I'd like to change my username here at the forum but didn't found any setting for so far.
