New File Versions Keep Getting Created
russtuff
russtuff
Well this is annoying. I have 4 files, each with a single part in them. I have then created a 5th file and used "Insert into current design" to create an assembly using all four parts. When I save the assembly file, all of my individual part files get updated and need to be resaved. If I close any of them (causing them to be saved) or save them manually, the assembly file then says I have out of date versions for each part file and I have to "get the latest versions", causing all of the part files to need to be resaved again.
rus, making stuff
youtube.com/russtuff
innovatenate
Autodesk Support
Autodesk Support
Do you have the xref'd designs (4 component designs) open while you are creating the assembly?
In Preferences there are two options that may be impacting the save behavior and creating new versions. There's the auto-save option (interval) and the save on close option in Preferences.
I hope this helps.
Nathan Chandler
Principal Specialist
russtuff
This takes care of that, thanks!
rus, making stuff
