Just installed Fusion 360 and I can't see anything.
Message 1 of 30
I just installed the program, it gave me a warning that my graphics card might not be up to the task of running everything, so I clicked the graphics diagnostis and checked the limit all effects to provide optimum performance box.  After that the entire screen is gray, I was able to perform the first tutorial(lamp base) with the screen all gray.  Objects only show up when I have the mouse over the object.  I tried uninstalling and reinstalling once already, as well as logging out and back in.
Thanks in advance
Replies (29)
Message 21 of 30
I am having the same problem. Can someone please help because I really need Fusion 360 to work! PLEASE!!
Smiley SadSmiley Happy
@chengyun.yang wrote:
Can you please let us know your graphics card configuration(GPU and its hardware driver version)? You can get this info in Computer->Device manager->Display Adapters->Driver. If your graphics card driver is too old (e.g., more than 3 years ago), then it is likely you could run into this kind of display issues(we once observed similar issues on some old Intel graphics card drivers). Please try to download/install the latest graphics card driver from your GPU vendor website.
Chengyun
Fusion Team
Message 22 of 30
adamsd5
Replying to my own issue here in case it helps.  First, I meant 'gray', not 'great' (autocorrect).  My Fusion downloaded an update today.  I closed and re-opened and the gray screen is not currently happening.  I'll keep an eye on it and see if it happens again and if I can figure out what triggers it.  For now, it's nice to see again.  🙂  As always, great product that keeps improving.  Keep going!
Darryl
Message 23 of 30
lt00273
Was the update automatic?
Sent from my iPhone
Message 24 of 30
innovatenate
Autodesk Support
Autodesk Support
@Anonymous In some cases it is helpful to uninstall the current driver first.
The below link walks through this process.
http://www.wikihow.com/Uninstall-Graphics-Drivers
Note that after uninstalling, you will run on the VGA which will make the graphics look really bad. This is OK, do not worry!
Next, per the suggestion @James.Youmatz made in this thread, you should install the latest driver from the Intel website, below.
https://downloadcenter.intel.com/product/81507/Graphics-Drivers-for-Mobile-Intel-4-Series-Express-Chipset-Family
After you have successfully installed the update driver, please verify that the driver update has been installed by running a Direct X Diagnostic test (procedure below):
  1. Launch %windir%\system32\dxdiag.exe
  2. Select Save All Information
  3. Please reply with the resulting *.TXT file attached
I hope this helps. Please let me know if you have any quetsions.
Nathan Chandler
Principal Specialist
Message 25 of 30
adamsd5
It started downloading automatically (thre was a progress count-up % in the GUI showing an update was downloading).  I presume it did the installation automatically also... but I was away from the computer at the time, and restarted when I got back... I guess there is a chance that the restart itself fixed my issue, but I don't see any pending updates right now, so I guess the update is done.
Message 26 of 30
Kenatic
Samething happens On my 2011 Macbook Pro quad 16gig with
AMD Radeon HD 6750M 1024 MB
I get the gray screen too.  It happens sometimes when have a design open, then I create a new design and both windows go gray.  Seems to happen if it's wanting me to restart the app due to an update.  But I cannot reproduce that test case.  Restarting the app fixed it (see second picture).
I did have section analysis turned on, if that matters.
Screen Shot 2016-02-03 at 9.45.30 AM.pngScreen Shot 2016-02-03 at 9.52.59 AM.png
Message 27 of 30
Phil.E
Can you try turning off visual effects?
If it happens again, check the graphics diagnostic to ensure your actual video card is being used. It's under the ?Help menu.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 28 of 30
Kenatic
It happened again, after a lot of tries, when I created a new file -- here are the settings (from the clipboard button).  I'll turn off ground shadow for a while.
[GPU Information]
GPU Device: AMD Radeon HD 6750M
GPU RAM: 1024 MB
GPU Driver API: OpenGL Core Profile
[Graphics Effects Settings]
Anti Aliasing: Off
Ambient Occlusion: Off
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Simple
Transparency Effect: Better Performance
[Notes]
The effects could slow down the graphics rendering; try to limit them for optimum performance.
[Limit all effects to provide optimum performance]
Off
Message 29 of 30
Phil.E
Nothing out of the ordinary there.
You do mention running two monitors. "then I create a new design and both windows go gray. "
This will add stress to the video card, but shouldn't cause this much trouble. Are you using any other video intensive apps at the same time?
Things to try:
  • Reboot your machine
  • Disconnect the second monitor, or mute the laptop screen.
  • Close any video hungry apps.
I want to eliminate variables here.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 30 of 30
hi,
i had the same problem of gray screen and i have nvidia quadro fx 4500 video card.
after installing all drivers and try to change graphic drivers from directx 11 to directx 9 without solving the problem, finally i fix the problem removing all graphic effects in the graphics diagnostic menu under the help button.
so thank you for your cooperation, hope my message will help someone
