Hi All,
ive been using fusions 2D sheet drawing function, which has been great so far, but one problem. I have many parts that have features that need to be dimensioned on both sides of the part. I cannot work out how you show both sides in one drawing... I get that you can select the base view, and then proejct out from there, but ive not been able to show both sides of the same part on the same drawing.
Any help?
Pete.
I've run into the same issue before, the projected views won't give you opposite side to the base view. A workaround is to add another base view, and choose the opposite view in the dialog menu. doesn't line up as nicely and doesn't move in sync with other views though..
Oh I wasnt aware you could have more than one base view!
Thanks for that, il try.
Pete.
