Constructware General Discussion
adilkhatri
Message 1 of 4 (2,144 Views)
Error While uploading files
2144 Views, 3 Replies
09-08-2009 10:15 PM
We are facing an error message while uploading file under file directory.
error Message :- Cannot Continue because no files have been specified. Please add file"
1. We are uploading only 1 file at a time
2. The problem comes if thye files size is more then 5MB
3. This error is irrespective to file type.
4. All the user on all computers facing this problem.
Attached is the screenshot for the same.
Employee
james.l.bryant
Message 2 of 4 (2,144 Views)
Re: Error While uploading files
09-09-2009 02:15 PM in reply to: adilkhatri
I believe this issue has been reported to Constructware.
You may want to try uploading documents using Java instead of Active X. When we upload documents to Constructware our PC will use either an Active X component or a Java Component. Constructware allows the flexibility to use either component. Please try the following:
File Director
Add File Button
The first window you receive will allow you to browse to local files on your PC, close this window
The second window you receive is the Constructware Add File Window (same window as in screenshot )
Locate the field called Levels of Reference
Level of Reference of 0 = Active x
Level of Reference of 1 through All = Java
Change the level of reference from 0 to 1
Click Add File again
Try reuploading the file
adilkhatri
Message 3 of 4 (2,144 Views)
09-09-2009 11:21 PM in reply to: adilkhatri
We tried that too but same error keep comming infact we are facing this problem in both of your project.
Employee
james.l.bryant
Message 4 of 4 (2,144 Views)
09-10-2009 02:06 PM in reply to: adilkhatri
The issue you are experiencing is a known issue. Constructware is working to resolve issue. A release is tenatively scheduled for mid September. You should create a Feedback case of this issue.
New Constructware Category!
The Constructware forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
