Solved by JackGregory. Go to Solution.
I am a little confused, so I need to ask some clarifying questions.
Is this a C360 issue, or do you have the same problem in Inventor ETO?
What do you mean by "place the second one"?
You say you have two assemblies. Do you actually have two iam files? If so, they will be unique. If not, then you don't have two assemblies.
As an aside, that may be entirely misleading, are you aware of the distinction between ivAssemblyDocument, and ivCustomAssemblyDocument? The latter will make unique instances, but at a cost.
A simple example will go a long way toward helping others understand what is going on here. Generally speaking, if you can't get what you want in Inventor ETO, then C360 won't be able to do it, either. So you need to focus on the Inventor side first.
OK.. I try to explain a little bit better..
It's a kind of C360-problem. As I wrote before, I have had this problem in ETO before and I solved it by adding a Constraint-child to my Assembly Document Design. But you can't have constraints-child inC360 and I'm not sure if it would help me this time either..
By "place a second one" I mean hat I have placed a dynamic child and then place one more dynamic child. They are the same if ju just look at the childs except for the placement. But all the child are placed in different places. If you do it like this ETO and C360 wil see them as the IAM-file even if all the parts are located in different Origins.
ivCustomAssemblyDocument did the trick!!
But if I look at ivCustomAssemblyDocument it says in the Help .."This design is now obsolete"..
Is it smart to use that in projects for the future??
/Rikard
I am not aware of a restriction on constraints in C360. Like I said, if it works in Inventor, it is supposed to work in C360. We have many customers using constraints, so I suspect there is something you have been told that is much more specific than you are assuming.
I am still not clear on the problem you are having. I assume you mean by "place" that you are using "Add Child" in Inventor ETO.
The ivCustomAssemblyDocument may now just be a parameter on ivAssemblyDocument. But I will check and post back.
